G450 Gear Pin Holder
1 year 11 months ago #1628 by OG GarlicSalt
Was getting sick of digging through the bag of pins in the door for the gear pins, so I created a 3d print model of a gear pin holder to make them easier to find. Made like the ones that come on the 650 not sure if this originally came with the aircraft and was lost or they never had one. Either way this fits the pins quite well, will have to see how it holds after time may need to change material after all the hot and cold cycles.
Printed : PLA
Print Time : 1:45
Print Cost : .25
File Download
File Attachment:
File Name: G450GearPins.zip
File Size:134.43 KB
1 year 5 days ago #1832 by SamAero
Replied by SamAero on topic G450 Gear Pin Holder
Hello,
Can you re-attach the file? When I tried downloading it, the print file shows up smaller than 1 millimeter size.
Thanks!
1 year 5 days ago #1833 by Mark
Replied by Mark on topic G450 Gear Pin Holder
I'll reach out to the poster to see if he can help you out.
1 year 5 days ago #1834 by OG GarlicSalt
Replied by OG GarlicSalt on topic G450 Gear Pin Holder
Yes tomorrow I will find the orginal file and make sure its properly sized, what print software are you using?
1 year 4 days ago #1835 by SamAero
Using Flashprint to print the file. Initially tried uploading to flashprint. Then noticed the insanely small size. Also, when I sized up the model to 4 inches, the holes became unnattached and not the best file. Do not beleive it is the printer. What should the dimensions of this be?
1 year 4 days ago #1836 by OG GarlicSalt
Try this file i re exported it after putting it in my print software, let me know if it works for you otherwise I will recreate it in autodesk instead of blender.
File Attachment:
File Name: G450GearPinsredo.zip
File Size:475.33 KB
1 year 4 days ago #1837 by SamAero
Much better! However, it comes out to being 84 inches tall. What dimensions should this drawing be when printed? It has some weird lines/cuts in it, but I can try to CAD those out.
Again, thank you very much for sharing.
1 year 4 days ago - 1 year 4 days ago #1838 by OG GarlicSalt
It should be 85MM the size is roughly 25.84x40.00x85. I made it all in mm.
Last edit: 1 year 4 days ago by OG GarlicSalt.
1 year 4 days ago #1839 by OG GarlicSalt
I think I see your issue, when I open the file in blender and Creality the model is sharp, I opened it in meshmixer and I see the odd lines and fragmented faces. I think it just comes down to the boolean operations destroying the faces. Let me know if your not able to get it to turn out I will re create it in Autodesk tomorrow.
1 year 4 days ago #1840 by SamAero
I dont understand what that means... haha
Thanks for the help, but it is still creating the weird lines on my side.
Time to create page: 1.005 seconds
