Time Delay Relay
10 years 5 months ago - 10 years 5 months ago #204 by Mark
Time Delay Relay was created by Mark
A little bit of caution is advised here.
Relay coils come in two flavors, 28VDC and 115VAC (400Hz). I've learned from personal experience.... using the wrong voltage to test one normally provides a "brief" moment of excitement. Sometimes this "excitement" is accompanied by a bright flash and possible smoke. (To be truthful, it was early on in my aircraft maintenance "travels". On a MD-80, I used 115 on a 28 volt relay with jumpers in the E&E compartment. I got that "flash" and luckily, just some popped breakers. I started paying close attention to coil voltages after that one.)
Last edit: 10 years 5 months ago by Mark.
9 years 11 months ago #244 by jake ounce
Replied by jake ounce on topic Time Delay Relay
I use that 9V battery trick to test relays too. It works great...click.
Time to create page: 0.935 seconds
