ATA 31-41 EICAS Maintenance Bypass Switch
3 years 4 months ago - 3 years 4 months ago #1131 by peter.waters01
I ran into an issue today that caused me a bit of frustration... until I came up with a workaround.
Most of the fleet of B767s I have dealt with have an EICAS maintenance bypass switch, allowing the use of the maintenance buttons (ECS/MSG, PERF/APU, etc.) while the aircraft is in AIR mode, whether in flight or simulated with actuators. During troubleshooting of an ELEV FEEL EICAS (S) message the FIM requires the aircraft to be above 270 knots on aux. pitot system 1, hydraulics on, and the aircraft in AIR mode. Once these conditions are met, the ELEV FEEL message is able to be cleared.
But, what can be done if there is not an EICAS maintenance bypass switch?
The workaround I found was to pull relay K202 (which controls the EICAS maintenance function), jumper pins 10 and 11, then perform the FIM tasks. Once complete, reinstall the K202 relay after removing the jumper and move on to better tasks.
Last edit: 3 years 4 months ago by peter.waters01. Reason: Operator error... first time posting.
Time to create page: 0.956 seconds
