ATA 24-20, A/C Power Control & Monitoring
9 years 7 months ago - 9 years 7 months ago #296 by Mark
MD-11 on short turn from MEM/IAH - IAH/DFW.
Inbound write-up and our action:
PDIS XXX 22-21 5004 21Mar17 IAH U CLOSE
Logpages:XXXXXXXX
ON APPROACH TO KIAH RWY 26L AT APPROXIMITELY
1500 AGL WITH AUTOPILOT DISENGAGED THE LSAS
LEFT INBOARD AND RIGHT OUTBOARD FAIL
ANNUNCIATORS ILLUMINATED IN ADDITION TO BOTH
LOWER YAW DAMPER A&B FAIL LIGHTS ILLUMINATED
UPON CONDUCTING GO AROUND DU'S 2 AND 4
REVERTED TO COMPASS ROSES AND AUTOPILOT
DISCONNECTED . AFTER A COUPLE OF MINUTES THE
LIGHTS EXTINGUISHED ONE BY ONE AND THE
AUTOPILOT WAS REGAINED.
ENT BY: XXXXX RPT BY: XXXXXX
R/I 21Mar17 22:08 IAH U
REASON CODE : PREMATURE REMOVAL/INSTALLATION
OFF
MPN: 750866D POS: ONL
SRL: XXXX TAG NBR: XXXXXX
ON
MPN: 750866D CPN: 2411639
SRL: XXXXXXXXXX TAG NBR: XXXXX
ENT BY: XXXXXX RPT BY: XXXXXX
FACT 21Mar17 22:08 IAH U
DUE TO MULTIPLE LRU ELECTRICAL RELATED FAULTS
REMOVED AND REPLACED EPCU REF AMM 24-08-01-4. RTS
CHECKS NORMAL. EPCU/FCC CAT 3 INTERFACE TEST ON FCC'S
1 & 2 ARE NORMAL. A/C OK FOR SERVICE.
CFDS showed failures all over the place for the last flight. All three IRS's and DEU's, both FCC's, both Cabin Pressure Controllers, a Radio Alt, and a VHF Comm. Our reaction...... "power" problem, but not a fault one for the EPCU (Electrical Power Control Unit).
We had a EPCU in stock and even though nothing was recorded as it being failed...... we changed it and kicked-um out of town.
On the next flight:
PDIS XXX 24-21 5006 22Mar17 DFW U MEL/CDL
Logpages:XXXXXXXX
TURNING BASE TO FINAL ON RWY 17C GEN 3 OFF LEVEL 1
ALERT ILLUMINATED . QRH PROCEDURE ACCOMPLISHED GEN
3 WOULD NOT RESET. UPON ROLLOUT GEN DRIVE 3 FAULT
LEVEL 2 ALERT ILLUMINATED.
MEL 22Mar17 00:17 DFW U
RELEASED FOR SERVICE PER MEL : 24-21-01
CATEGORY : B EXPIRATION : 25Mar17
"MEL 24-21-01: NO. #3 IDG - INOP AND
DISCONNECTED. OPERATE ELEC IN AUTO."
C/7088825 ENT BY: XXXXXX RPT BY: XXXXXX
What was perplexing about this was the fact that the #3 generator must of glitched coming into Houston and "nothing" was recorded as a fault. In the case of the arrival here, all the components listed above lost power which was long enough to cause a restart. It's actually a good thing this was on a MD-11 instead of a MD-10. Equipment on MD-11's, power up quickly. MD-10's can take over two minutes to come online.
Last edit: 9 years 7 months ago by Mark.
Time to create page: 0.988 seconds
