Wire identification mark
1 year 9 months ago #1648 by dynamics
Is it possible to identify bundle number as per WDM from wire identification mark?
1 year 9 months ago #1649 by OG GarlicSalt
Depends on how robust your manual is. If it's boeing you should be able to find a bundle from a single wire, assuming from wire identification mark you mean wire number, just cross reference with wire number with bundle list and you should be able to find it.
1 year 9 months ago #1651 by Mark
Replied by Mark on topic Wire identification mark
Unfortunately, bundle uniformity on older aircraft with numerous wiring modifications and repairs becomes less organized for formal location of actual wire runs.
Out of the factory, bundles are identified by colored tie-wraps (red for pilot's systems, green for co-pilot systems...), if those particular color tie-wraps aren't available after a repair, white is used. Pretty soon, everything has white tie-wraps.
We locate wires in bundles by using a "fox and hound". We trace the tone which helps identify which bundle a particular wire is in. We have to cut tie-wraps and spread wires apart to find the exact one we're looking for.
Time to create page: 1.054 seconds
