Daniels Tooling Guide
5 years 3 months ago - 5 years 3 months ago #749 by Mark
Daniels Tooling Guide was created by Mark
Last edit: 5 years 3 months ago by Mark.
5 years 3 months ago #753 by Clipper
Replied by Clipper on topic Daniels Tooling Guide
Looking thru that catalog, made me wonder the same thing back in the early 2000s when GM was sending trays and trays of terminal pins to dealerships. Why on earth do we need a gazillion different terminals? I guess the short answer is...That's Big Business for you! But how much easier it would be if it was standardized to 50 different terminals and mating halfs!
5 years 3 months ago #755 by Mark
Replied by Mark on topic Daniels Tooling Guide
Different current or signal needs. Different jack/plug sizes are intentionally used. Different keying is used also.
It is not uncommon to have a vertical stanchion that has 50 plugs on it. Most if not all, will be different types and sizes.
Why???? To keep from putting the wrong plug on the wrong jack.
Bad things happen...... like..... crossing the streams.
5 years 3 months ago #759 by Clipper
I'm all for not crossing the streams! But having different connector bodies that prevent cross mating might be an easier solution, and aren't as breakage prone as the pins are. Unless its an older Ford, all you had to do was look at a connector the wrong way and it broke lol!
Time to create page: 1.012 seconds
